skier-hughes
- Staffs, UK
I'm considering the approach I take to the ceiling in the bedroom.
The woodwork is I believe known as a cruciform design?
You've seen the pictures previously, so here's another, but there are two large main beams forming a +
Then in each square we have beams that look like this
- I
I -
Now, should I just use plasterboard to make the ceiling?
If so, due to the age and condition of some of the beams, would I be better screwing the plasterboard down?
How about using a thin piece of ply to help distribute the force of the screw?
I'm thinking this as the beams do go merrily up and down wherever they want to
I'd then give the plasterboard a skim over with plaster.
Are there any oher options I should be lookng at?
I thought about boarding it, so really using floorboards, but this would add enormously to the cost.
It would though give me a walking space in the loft, without trying to guess where the beams are to walk on!!!!!
I can see a post in Graham's top tips coming here!!!!
We ahve no intention of moving up into the loft space.
None of the upstais ceiling are original or date back from before 1951, so I have no idea what might have been used previously.
There is no indication that lath and plaster was used, ie no plaster on the beams, no grooves for the laths to fit into, which the uprights have.
- I
I -
