Causes of damp on internal walls, in order of likelihood:
1. condensation. Cause: interior RH too high. Solution: find cause/s of high RH and fix em.
2. Faulty roof or rainwater goods dumping water onto the wall. Solution: clear gutters and hoppers, check rain drainage works ok, or fix roof.
3. Leaking plumbing
4. Salt contamination: this tends to happen to chimneys mostly, but can also result from iron pipe fixings or spillages. Solution: remove and replace plaster
5. Peeing: animal or small child peeing on wall. Solution: retrain.
6. Rising damp: it does exist but is rare. If every other cause has been ruled out, and every necessary measure taken, inserting a dpc just might work. Almost all rising damp diagnoses are false.
NT
ps please ignore the poll... couldnt help myself
3. Leaking plumbing
NT
