d49xc
- Central Southern UK
I’m trying to remove a standard 3inch 'cast iron' rainwater downpipe socket from the adjacent section.
Pipe loosely fits inside socket end of next section and gap between sealed with putty. Over next 80 years the whole lot expands and rusts solid and is extremely difficult to remove without cutting the socket off as I know from others around the house.
Picture at https://copy.com/HA0EtE8vDZvd
As you can see from picture next section with the socket on disappears down into ground adjacent to a large bush so I really do need to remove the bend section without breaking the socket.
Somewhere below that the soakaway/bottom bend is blocked with roots/muck…hence the issue - I'm hoping I'll be able to water-jet the whole lot out once I get unrestricted vertical access from the top.
So far I’ve tried digging out as best as I can the putty sealing the gap between the pipe and socket. I’ve tried stuffing a load of rust releasing fluids down gap.
Tried the usual “not too much force”. Tried a bit of heat but I can’t really get a big enough temperature differential between inner and outer to release it. So far the pipe bend is totally solid and immoveable within the socket.
I’m rather running out of ideas……
The “final solution” of course is to cut off the bend level with the socket top and then cut away from inside the pipe the remains of the cut-off section from within-side the socket. Given that the inside is less than 3” diameter so too small for an angle grinder to get inside this isn’t going to be easy either.
Fortunately time is not an issue as I’ve diverted the rainwater elsewhere temporarily so if it takes me a few months on and off so be it.
Anyone got any suggestions?
