A
Anonymous
Guest
I wonder if anyone can help with a problem I've got? I've recently purchased a cast iron combination fireplace and I'm in the process of fitting it. I a few questions I hope someone can help mw with;
1. If I attached the fire place directly to the plaster on the chimney breast, how do I seal the fire to stop smoke etc. from staining the plaster above the shelf?
2. If I plaster the fireplace into position will this be a sufficient seal?
3. I've heard fire rope can be used to seal fireplaces. Where does this go?
Thanks for all your help
