worms
- ultima Thule
How does one correctly mount a cast-iron down-pipe onto a rubble stone wall?
All of mine are merely held horizontally to the wall by a spike/hook with an opposing wooden wedge but held vertically by a cast-iron bend at the bottom, which in turn is held by another section of cast-iron down-pipe laid at an angle underground into the soakaway. This arrangement makes it impossible to clear the downpipe without dismantling all the way down to the soakaway.
I want to terminate it at the bottom bend and make new arrangements for the soakaway, but need to be able to keep the pipe supported. Inevitably the flange section of the downpipe where you might mount a bracket is never in the right place to fix screws into the rubble wall. In a couple of places where I have done a botch repair with a plastic downpipe, I have mounted a block of onto the wall and then the pipe fixings onto the wood. But there must be a more elegant solution!
