fallingditch
My cottage is lowlying on the Essex Marshes. No foundations, no DPC, no DPM. 50% of the floors are wooden - 50% old concrete. The wooden floors are suffering from wet rot and need replacement. So seems to me, the advice offered by Groundworker (on 15 July 2005): "Cancel the concrete. Seriously, it's the wrong thing to do. Excavate the floor to 175mm below your finished floor level, pile in a few tons of 50mm down type 1 limestone, level it out to about 100mm thickness and wacker plate it thoroughly. Lay the flags on a bed of sharp sand. Set up some string lines in the room to level each flag individually by adjusting the quantity of sand by hand with a trowel. I'm guessing you should be able to get flags about 50mm thick but when you lay them like this they don't have to be truly consistent - you just adjust each bed of sand. It's a straightforward dry job, no concrete, don't bother with a dpm. Get a good heavy rubber mallet." is pretty sensible ...
If I am prepared to live with cold floors why would I want to do anything more sophisticated than this?
