hi there
please can someone explain a couple of things to me in laymans terms if possible;
1. why do modern timber frame buildings not require the use of lime and breathable materials to stop the frame rotting, as in older buildings,
2. is it ok to use normal plaster board and plaster between beams say for example in a ceiling, ie does the breathable materials just need to be used on out side walls.
3.what options are available for flooring in a timber frame cottage, we have dug out the floor to approx 200mm below the sole plate, ideally we would like underfloor heating but with an oak floor finish, this appears to go against the grain of then having a breathable floor apparently, because the oak would be sealed, please correct me if im wrong, also i would like to salvage some of the 200mm to allow extra head height or should i go down further. we are also lowering the external levels the same. Does the floor still need to be breathable this low below the timber,
4. eventually we will be internally and externally re plastering the whole house, so we felt the best bet would be to buy the lime by the tonne (not tubs) mix and leave to cure, can this be stored in say black bins, and for how long,
5. also when using bulding boards, would this then require one skim coat of lime or still the three coats like lathe.
i know all these questions have been answered im sure, but when i try to search its says theres nothing matching, or those that do do not specifically apply,
so i appologise in advance, and thanks, i find i am reading so much and getting so many differing opinions that im getting bogged down and waylaid from the original questions.
