When I hired a propane space heater for a church last November, they said that if it was on for any length of time then I would need two large bottles (both connected) as one bottle would empty so fast that it would freeze and become unuseable, as skier-hughes says. But that was inside a building at about 10 deg C!skier-hughes said:In order to be usable, the liquid in the bottle must be able to boil into a gas. In the case of Butane, this will happen at any temperature above -2C, whereas with Propane, this figure is much lower, at -42C. In the real world, it's not so clear cut. Whenever some of the liquid boils into gas, the remaining liquid cools. It is therefore possible for the temperature of the liquid to drop to several degrees below ambient. This can easily prevent a Butane canister from producing a useful gas supply, even when the outside temperature is several degrees above 0C
A small improvised camp fire should do the trick. :wink:Feltwell said:What I need is a heater to keep the heater warm!
Balmy 11 degrees C here in the "frozen" north!Feltwell said:One is freezing one's wotsits off working out in the garage today - because it's too cold for the butane powered cabinet heater to work properly :evil: What I need is a heater to keep the heater warm!
Wash-house? Forge? Branding irons? Refuge from the missus?Flyfisher said:I've often wondered why the fire and chimney was built originally though as it's hard to imagine that the outbuildings were ever anything more than just, er, outbuildings.
worms said:Wash-house? Forge? Branding irons? Refuge from the missus?Flyfisher said:I've often wondered why the fire and chimney was built originally though as it's hard to imagine that the outbuildings were ever anything more than just, er, outbuildings.
Lime said:It gave me a tangible understanding of the Space Shuttle crew's experience who died in a fire on the launch pad when a high pressure oxygen pipe broke free cutting them to pieces.
