If you have penetrating damp, you should resolve the issue allowing damp to penetrate. If you don’t have penetrating damp then it’s back to the question: what selling point do these boards have vs the standard breathable IWI systems, namely wood wool, wood fiber and agglomerated expanded cork?Company have told me this is the best option for my house. Advised against woodfibre. I think there advise was mostly due to concerns about penetrating damp (although this isn’t a major issue for us). But I’m wondering if they will give us the thermal insulation we’re looking to achieve.
You should ask the people recommending them to you. If they can’t give you a clear, rational answer then it’s likely some BS ulterior motive.That’s what I don’t know.
Can you put a link up to the product?What are the general opinions of calcium silicate boards combined with thermal lime plaster for solid red brick Edwardian internal wall insulation? Worth the investment?
Agreed, I thought the board product PLUS an insulating plaster is a particularly strange recommendation that raised alarm bells for me as well. That insulating plaster won’t do much unless it’s built up thickly, but how’re you supposed to build up a few CMs of plaster onto a flat board product with no mechanical key.Can you put a link up to the product?
The inclusion of thermal plaster raises alarm bells for me, its not really a serious option for insulation unless you've got nice thick walls like aockenden. Wood fibre board is the tried and tested way that many people follow. If your walls suffer damp you need to eliminate that first before insulating. Incidents of rising damp are very rare (imho) unless you live on a high water table or rainwater management is poor or faulty, so its a mute point.
Only you can decide how much insulation is enough for you to live comfortably in this place. Personally, I hate sitting next to walls which are radiating coldness at me, and I hate sleeping next to them as well.Thanks for all your advice on this issue. We’ve ruled these boards out now based on the advice here. Also they’re extremely costly. We’re swaying towards wood fibre boards or wood wool boards. The company advised us against these and they said they would get damp but I’m not really sure why. We were thinking of not doing any IWI as it’s just seems to garner so many different opinions, but I’m not sure plaster alone alone will be enough. Ideally, I want to insulate over the existing lime plaster, except for one room where we had to remove all the plaster due to modern plasterboard causing damp and ruining the original lime plaster underneath. We’re replacing the windows, insulating under the ground floor and have insulated the roof. Is this enough??
