jamestyler
Hi
I'm looking to buy a stone built house, circa early 1800s. It's quite large, 2500sqft, 4 beds.
We've had a damp survey from an independent surveyor, who has no interest in selling us services. We picked him as he has a good repulation, after some concerns raised on building survey. Rest of building survey was pretty good (ie no structural, roof issues, etc)
The report has raised that =:
The right hand gable end wall is showing high moisture readings from ground level to top of 1st floor.
The timber that could be measured abutting this wall showing 40%+ moisture reading. Couldn't measure floorboards/joists.
Downstairs on that same wall, a wooden bean going from floor to ceiling is showing 27% moisture readings.
Front and rear elevations can't be measured, due to plasterboard on wall (no visible damp)
However, the dividing walls going at 90 degrees to front elevation show high moisture closest to the front wall
Rising damp, no DPC is most of building due to age
Internal plasterboard has no visible signs of damage, but we can't access behind
Surveyor has recommended repoint, which will be very expensive as it's random stone, needs cement patchwork manually raking out and replacing with lime), then a silane siloxane water repellant added.
Due to the drylining on most walls, recommended we access behind this to see how it's looking. If attached with timber battons, these would be likely damp, and would need plasterboard/batons removing, cavity drainage membrane fitting to wall, then replasterboarding over the top to isolate the wall from the plasterboard.
So...
I'm OK with the repointing if we can agree a reduction in price to cover this, but the big unknown is the plasterboard. If we have to strip, add a membrane and replaster, that's £1000s of cost, and a huge amount of disruption. It doesn't sound particular sympathetic to an old building and I'm not sure I like the idea of living in a tupperwear box.
As there's no visible signs of damp (or smell) downstairs (there is upstairs near gable end), then I'm hoping there isn't an issue, but it's such an unknown/risk.
Any advice from people who have experienced similar problems would be much appreciated as it's quite difficult to interpret all these different reports and opinions and I don't want to jump into a purchase ignorant and end up paying out huge bills.
I also have a mould allergy and a 12 month year old daughter, so our health comes first with all this.
Many thanks for your advice
So...
