please be gentle, I've lived in old houses (victorian and edwardian) all my life (32 yrs) and done up 3, but none of them were even in a conservation area let alone listed. For our next move we are looking at a georgian Grade II listed building and I have a few questions, I've done research and I plan to talk to the local planning dept but I'm trying to get as much ino as psosible before we decide whether to buy or not so here goes;
1 WE've viewed two houses both georgian Grade II listed and both the owners said that the planning dept/conservation officer is really only concerned about the frontage of the house, is this likely?
2 The one we are keenest on is a 3 story conversion from an old mill building, apart from the basic structure of the building and one door on the ground floor there isn't a single feature inside the property, no skirting boards even! Does this mean we'll have less hassle doing up the inside?
3 It needs complete renovation, there isn't a kitchen in there at the moment and generally it hasn't been touched since around 1965 (old lady, being sold by family) Are there any restrictions on kitchens/ plumbing/ internal wiring/ central heating
4 There is a stonkingly ugly leanto type extension (very small only 5ft by 5 ft) at the back of the house. We'd like to replace that and have 4 options from the one that gives us the most space to the one that replicates what is there.
a) demolish existing extension and replace with a 6 ft square double height extension at other side of house (a move of about 5-10 ft basically so it opens off from the pantry rather than by the chimney breast which is awkward). This would give us a utility area/porch on the ground floor and a small bathroom of the landing on the first floor
b) demolish existing extension and move to other side of building as above, link extension to old outhouses to create larger (6ft x 12ft) kitchen space.
c) demolish exisitng extension with large extension (6ft x 6ft or 5 ft x 7ft) on same side
d) renovate existing extension to create better use of space.
All of this is because its a very narrow and tall building, the living room at present would be the front room on the ground floor which opens straight in off the street. You have 2 rooms on each floor which gives you 3 bedrooms and a bathroom on floors 2 and 3.
We'd like to be able to have a sitting room on the first floor for a bit more privacy and a larger dining kitchen on the ground floor, if we can create a small 'boxroom' bathroom via an extension that would be perfect!
(sorry if thats just tmi)
Finally, its got old (but apparantly not orginal) single glazed sash windows. I seem to get conflicting advice about this, can you replace a timber framed single glazed sash window with a double glazed timber framed sash window made in exactly the same way to fit the space.
Any other hints and tips are very welcome.
