I've been working on my inglenook fireplace and had a couple of questions. The 'inglenook' is about 1 metre by 3 metres. Within this a brick chimney has been built leading to a vaulted brick ceiling at the level of the main beam over the fireplace. The flue then continues at 1mx3m above this to the pots at the top.
The back wall inside this inner fireplace was rendered very badly (looks like a ten year old had done it) in a cement render, trapping the moisture in the stone and bricks of the inner chimney. I've now removed this to be left with a part stone, concrete block, brick and anything else that came to the bodgers hand when he rebuilt this section. It's now thankfully drying out very quickly but I'm still left with a hideous wall at the rear of the fireplace.
I'm loath to rebuild this as the outer skin of this area (gable end) had a big hole punched into it by a digger (demolition of attached building by developers next door - don't ask!) and I don't want to put further stress on this area by removing a section and rebuilding.
So I'm proposing to re-render the inside of the fireplace with a lime render.
Does anyone know if there are any building regs governing the materials that can be used within the fireplace - it was previously rendered at some point in lime as there are remains of this.
And as an aside - why is it called an inglenook? The name conjures up a small cosy affair - something at odds with the hulking great thing (in a nice way!) that's in place now.
Photos can be provided if required.
