Zebra
- St Albans, Hertfordshire
Bit off topic, this, hope you all don't mind. My friend Giraffe has recently moved, and wants to build a shed - a large one, 4m x 6m, or 12ft x 20ft or thereabouts, for all his car and welding stuff. He also wants to be able to roll a small car inside (he currently drives a Smart Roadster) and do long term projects in there, like engine swaps, but this would probably not be very frequent.
We are considering options for the base. While concrete would seem the obvious choice, we are also aware that it's his girlfriend's house, we very much hope they will stay together forever but it would be an advantage if the thing were not too very permanent. And a concrete base that big, to the recommended depth with all the compacted sub-base underneath, adds up to quite a cost, plus it's not great environmentally. But it does make for a solid shed base.
An alternative as I see it would be brick piers set on concrete pads, then timber beams - plenty big ones, and a thick ply floor. You might have problems with heavy hammering as the floor would have some bounce in it, but I reckon if you knew where the piers were you could jack a car up on such a construction. You'd have to ventilate underneath, clearly, but the whole thing just seems a bit more manageable and DIY-able than concrete.
Are there any other options I've not thought of? Cost is a consideration, as is environmental impact.
