88v8
- Glorious Gloucs
The simplest things.... Never really stopped to think about how the builders of old fixed the sole plate to the dwarf walls. Not with screws n plugs, given that they had neither. Did they fix it at all??
Perhaps they had the right idea....
So, here's the start of the timber frame of our double garage, 4x2s on a 4x2 or 9x2 sole plate, fixed to a brick & Bradstone & block wall with 130 x 8mm coach screws in 12mm plugs.
Treated, graded, timber, was quite fresh when the frames were made up. I made two of the frames, the builder so far made two.
Fixed about 3/4 days ago, by packing it up, with the intention of pointing in later.
Today, I noticed that some of the bricks and Bradstone have pulled off.
I guess.... the builder may have overtightened the fixings, given there is no mortar bed yet.
Especially as most of the fixings have no packing directly beneath.
Or, perhaps we should have put it on a wet mortar bed as he first proposed - if so, that was my fault as the packing up was my idea because I thought it would be easier and I'd done it before. But that wasn't with newly treated timber.
Or perhaps some of their bricklaying was careless, they didn't seem that particular about brushing off dust & debris before laying the bricks.
I could also nitpick about their mortar, which they sometimes mix starting with wet sand, and have on occasion gone on using most of the day by knocking it back, a practice I eventually forbade. One hesitates to criticise one's builders, mostly, and he came highly recommended.
The mortar is cement + soft, some of it is white cement but only for colour.
Anyway, we have more framing to put up - is there a 'best way' to go about fixing the frames to the walls? Or should we just loosen off the fixings, reattach the loose bricks, and point under the frame before continuing?
Ivor
Ivor
