darrylmg
- Cheltenham, UK
Hello All,
Well I have spent a whole heap of time reading this forum.
It's very thorough and helpful.
My wife and I have recently moved into our new cotswold cottage which we think was built in around 1880.
Originally it would have been two or maybe even three seperate cottages as we can see three front doors and we have three chimneys and multiple fireplaces.
At some point it was converted into one large rectangular building.
We are currently having the electrics done replacing the old 10+ years of dodgey cabling jobs, plus removing unused rubber cabling and lead cabling and lead piping. I'm going to make a fortune with all that lead...
Looking at the front of the house we have the dining room with master bedroom above, on the left hand side. In the middle we have the lounge with the second bedroom and bathroom above. On the right we have the kitchen with the cellar below and third bedroom above.
Incidently, on one of the other posts I was reading about some people with floorboards in the kitchen. We have those too but to solve the crumbs problem, just put a cellar underneath like ours! You can hoover the crumbs in the cellar ;-)
The construction seems a little odd to me, but it may have been the "in thing" at the time.
The back wall of the entire house is cotswold stone, the sides and front are brick intermittent wth wood and with no cavity which has been rendered with pebble-dash. I suppose brick was modern and expensive back then.
Inside we have lime plastered walls with horse hair (I'm assuming it's not any other animal).
Any way, we are looking at renovating the dining room.
Currently it has a very uneaven floor that seems to be made up of original flagstone (probably on clay) intermixed with sections of concrete plus some paint and glue, then underlay and carpet.
We are thinking of two options to correct the floor:
A, Remove concrete, install matching flagstone to entire floor.
or
B, Remove all flooring including remaining flagstone and put solid oak.
:?: If we were to go with option A, what method did people in the cotswolds use to lay the foundation for laying flagstones?? I'm worried that the concreted will have been layed ontop of modern hard-core.
:?: If we were to go with option B, what method could we use to provide a firm surface for laying a solid wooden floor. Is this a possibility at all since there are conflicts?? i.e. the wooden floor wouldn't like moisture, yet the floor MUST breath.
The second issue we have is that the back of our house is a path next to a quiet road.
We have a gutter that runs the length of the back wall with one downpipe on the left hand corner of the house.
At the moment the downpipe just drops onto the path with the shoe pointing away from the house.
The surveyor suggested getting a channel put into the path that would carry the water into the road. I believe he was worried about it being slippery to pedestrians. :?: Has anyone had this done? What's the cost? The path is owned by the council.
Thanks for any help, it's much appreciated.
or
