Scenario:
1) Breathable IWI to be applied to 2 externally facing walls in each of the living rooms will require breathable paints. What happens to the remaining 2 walls that will not be having IWI applied in terms of paint work, I'm assuming standard paints can be applied to the non IWI walls. This will probably pose a challenge as its going to be difficult to get precise colour match between the 2 sets of walls.
How would you overcome this scenario?
2) If for example some of the rooms of the house are getting IWI whilst others are not, is there an inherent risk of causing issue to the externally facing walls of the property that are not getting IWI?
