Victoriandad
Hi Everyone,
First time posting here and I sincerely hope I can get some advice!
We moved into our Victorian terrace last year, there were issues with damp and I have completely replaced the sub-floor (sits independent from external walls), added numerous new air bricks and cleared 3 skips of crap from the sub-floor area.
I recently discovered a damaged waste pipe which was leaking into the ground below the patio. This had loosened 2 bricks at the bottom of the footing (spreader course), the bricks are at the junction between the house and kitchen (side-return). I have repaired the brickwork and it doesn't look like any other footings are in any way compromised.
During my investigation of the above problem, I noticed that the original kitchen DPC actually sits below the existing patio and only 3 courses above the footings. The DPC on the adjacent wall (dining room, french doors) is 1 course lower than the kitchen. There is musty smell in some of the kitchen cupboards and the floor is poured concrete. None of this was picked up on the Survey.
The course of bricks immediately above the kitchen damp course are badly damaged in some areas.
So, I am removing the patio and want to lay either yorkstone flags or gravel, but, I only have 265mm from the DPC to the top of the first spreader course footing. Ideally the patio should have a sub-base or at least 75mm with 30mm bedding layer and 50mm flags, that would only leave 110mm below the kitchen DPC and even less below the dining room DPC.
1. My understanding was footings are only disturbed if I dig below a 45 degree angle? Could I safely excavate to the top of the final spreader course, giving me an extra 85 mm?
2. Being so close to the footings, is it safe to use a wacker plate to compress the sub-grade & sub-base?
3. How serious a problem are the damaged bricks and should I remove the 'render' which covers the 2 course of bricks below the bell-cast?
