Hello all.
After receiving some extremely useful replies to my previous posts I thought I would try to tap into your collective experiences and knowledge regarding my loft floor.
My house is a large stone built property over 300 years old. The loft has been converted and boarded previously, but over time has sagged and become a little "bouncy". I believe it was the grain store as the house was previously a bakehouse.
With a new offspring on the way we need to use this as a bedroom and I am endeavouring to tackle the lack of insulation and uneven floor.
The room is approximately 6 m long and 5m wide. The joists currently run side to side spanning a central oak beam, overlapping in the middle. This means each beam goes approx 2.5m from the centralbeam to the wall.
Unfortunately they do no sit directly on the wall plate, but are screwed/bolted/tennoned into what appears to be old small "branches" approx 2 inches thick going down at an angle to the wall plate (i hope this makes sense)
The rafter are approx 4x2 thick and are all at the most 12 inches apart. I am thinking of screwing thin pieces of wood to the top of each rafter and laying flooring over the top to level it up.
My questions are:
Will this be strong enough to use as a bedroom?
Will the flooring help the overall stiffness?
Should i add additional noggins between the joists?
Any other ideas?
Any advise or experiences of a similar nature would be most appreciated.
Rob.
My questions are:
Any other ideas?
Rob.
