Niall
- MidLothian
TLDR: has anyone got experience of blown breathable insulation behind lathe? This place chats lots about wood fibre board vs other solid insulation but far less about blown; while Historic Scotland has it as their No. 1 option for pre 1900 houses. Why is that?
Situation. So I'm up in Scotland in a 50/50 Georgian/Victorian house with solid stone walls perfectly livable but a need for insulation as we refurb. We've insulated the loft and double-glazed the sash in the original case windows; now looking at the floor and walls as we look to instal a new kitchen.
Walls. Floors seem ‘easy’ but the walls are the meaty question. Walls were helpfuly lime repointed by the previous owners and in good nick, keeping pretty dry. There's one area of legacy damp from a roofing issue that in hand. House was originally early 1800s Georgian but aparrently doubled in depth in Victorian times with extra set of rooms. There's solid supporting walls that delineate this front-back split.
Internally. Walls are a mix of Georgian ‘tight’ but not ‘on’ to the wall plaster in the front rooms. While the Victorian rear is far more ‘hollow’ to knock lath set further off the wall. Most rooms are nicely corniced but the main wall coverings all need refreshed/repainted in the next few years. Therefore I don't want to strip back to stone to protect the cornice, but holes in the walls are fine.
Blown vs Board. Historic Scotland comes in strongly for blown breathable insulation (see link), while these forums seem to favour fibre board. Blown suits me as its holes at 50-100cm spacaings dependant on the fill. Plus work to the floor and skirting to avoid it leaking out into the solum.
							 www.engineshed.scot
					www.engineshed.scot
Question. Has anyone tried blown insulation behind lathe and plaster and if so what to I need to confirm before I commit?
- minimum depth to make it worth it?
- common issues?
- differences in different fills?
- can I mix and match wood fibre on the front rooms with ‘thin’ spaces and blow the rooms with some depth? Or is that going to be a problem?
- can I do areas as money allows or is blown done best in a one-er?
- anyone got a ball park figure per m2 or depth?
Grants. Helpfully in Scotland I can get £10k in grant/interest free loan for walls which may help a little.
Engine Shed advice on how to insulate stone walls
Find out from the Engine Shed how to insulate stone walls to improve energy efficiency, including details of the five main wall insulation options.
				 www.engineshed.scot
					www.engineshed.scot
- common issues?
