Is it a cavity wall? if so, you will improve your sound insulation if you brick up both the inner and outer ventilation holes in the wall. Sound penetration is best prevented by having several surfaces, and as much mass as possible to insulate you from the noise.Eremos said:Thanks for the comments. The vent is in one of the bedrooms. There isn't actually an air brick. What I have is an grille on the outside of the house, and it is completely open to the wall. So when a car goes past outside the house I can hear in the room as there is a "hole" in the wall with only a thin grille on the exterior.
I assume that this vent was to ensure that the room didn't get condensation when it was built. Is it still relevant now? The house has double glazing with trickle vents, etc.
My plan was to use some bricks on the inside and then plaster the "hole" in the wall on the interior side. Will this cause any problems?
It's a fact that buildings should be well ventilated, but there comes a point where you have to strike a balance between that and comfortable living. After all, how many houses have you seen with a bl**dy great hole in the bedroom wall?! And you have got trickle vents in your windows.Eremos said:Is it best to brick this kind of hole up?
