We want to sort a damp problem around the side of the house and the back door. Currently the area is concreted, which we are keen to remove as the inside floor level is lower than the concrete outside, and we were thinking of putting a grating / grille (with an "e", before Penners gets me...) to allow the wall to breathe. But there are a couple of drains in the way, and the grating solution looks expensive.
Would block paving on sand with a french drain under it be suitable? We can connect into the main drains so no problem getting rid of the water.
Or any other suggestions?
cheers
TT
cheers
TT
