Baron de Gynes
- Herefordshire, UK
Hello to one and all,
After lurking on here for a good while, enjoying the advice and banter from afar, I now find I need your collective assistance.
After moving into this house last September, a few works have been done but last year's hot summer and this year's harsh winter have taken their toll on the exterior of the house. It's a Grade II listed farmhouse constructed of a mix of stone and timber frame with brick infill panels. Some of the elevations have, in the past, been over-clad to add extra insulation. Whether that is a good this or not, I'm afraid the jury's still out, but the main framework, visible from inside, appears in good condition so the exterior cladding will have to remain for the moment.
The big job for this summer is to get the house painted and I'm not sure what to use. A forum search (back about 3 years) didn't flag anything obvious up, so I could do with your help. The house is currently a mix of white / off-white / cream with black-painted beams. I know that the beams shouldn't be painted, but the vast majority of buildings in the locality have the same treatment and, for ease, I'm planning to do the same.
The 'white' is flaking off in places, particularly on the brickwork which takes the brunt of the weathering; seems to have been done with a water-based finish.
I'm hoping to use oil-based paints because I believe they will last longer but I'm mindful not to use acrylic-based gunk. There haven't been any breatheability issues in the past, but I don't want to introduce them by using the wrong paint.
If possible, I'm hoping for a repaint in off-white with matt (just not gloss) black for the woodwork.
I also want to be rid of the horrible horrible horrible brown stain on the windows. It is old and flaking, so surely a good sand, primer coat and (preferably oil-based) white topcoats in white should suffice? The CO has no problems with the change and said consent would not be required. Woohoo! This is another query though - the windows are (I think) softwood and in fairly decent condition, although some require a bit of attention. I know that paint hides repairs well. Will the white look right, though? I don't like the dark windows, but am I doing the right thing? Opinions gratefully received.
Here's to the crux of my problem: (At last, you cry, he's got the point - I know, I'm an arch-waffler, sorry)
What paint should I be getting?
Linseed - seems expensive and, although breathable, most of my woodwork is covered up with what appears to be non-breathable paint....
Silicate paint - would have to go back to bare for that. No.
Water-based paint - isn't going to last as long as I want, although F&B (yes, I know, I know, but *I* like the stuff) has an impressive array of colours - I'm thinking Wimborne White or Pointing for the walls...
Oil-based - Where can I get it? So many paints are advertised as 'solvent-based' but with no mention of oil... This isn't the stuff, is it?
There are areas of the house that I can't reach so I'm reaching for the wallet and "Getting a Man In" - my favourite type of DIY. I've found a reputable painter, but I'd like to make it at least *look* like I know what I'm talking about with regard to the paint.
Please excuse my plaintive prattle.
