Matthew309
- Hampshire
Hi all
I have an old 150yo cottage with 9 inch solid wall on load bearing walls, and single skin on gable ends. The bricks are red brick and very porous and soft. The house is in full demo at the moment right back to brick.
I want to improve insulation and sort the damp problem, both penetrating and rising.
Things to consider:
I'd be interested to know people opinions, there no "correct" solution here imo that's doesn't have some form of downside, unless I've missed something?
Things to consider:
- Water table is 15 Inches from ground level
- Foundations at only 4 bricks deep on clay
- No original dpc ( signs of retrofit but compromised)
- The houses original suspended floor is now a dpm lined concrete floor
- Build 30mm cavity wall with cls timber and add cavity vents, this solves both rising and penetrating damp and prevents mould. But reduces room size and looses thermal mass of wall, chances of spallng damage long term.
- Add insulated plasterboard directly onto wall and tanking the base. Utilises thermal mass, more space efficient but high risk of interstitial condensation.
- Use old breathable materials (something I'm not sure I'm willing to do as that requires removing 80sqm of good concrete flooring.)
