djellworth
Hello All
When we moved into our victorian terrace we inherited an unused belfast sink which we are now trying to put to use in the laundry (basement) room.
Having realised how shockingly heavy the damned thing is (100kg?) the next problem is that the only waste I can get hold of is 1 1/2 inches - it is a slotted waste to account for the built-in overflow. Now the problem is that the actual hole that this fits into is more like 2 1/2 inches so:
- the chrome plug hole looks a bit small (but not the end of the world)
- the plastic locking nut barely covers the hole underneath the sink when I try to secure it - there is no way this will be water tight without serious fettling
- the chromed threaded down-tube is really difficult to centre
Some questions:
Can I get a 2 1/2 inch waste? - I have googled at length to no avail
Do I fashion something to hold the waste central?
Do I use masses of plumbers mait/silicon sealant and so on and jam the thing up to try and make it water tight? - although I fear this will result in blocking the overflow slot....
Advice gratefully accepted
cheers
Nick
Some questions:
cheers
Nick
