segiffin
- north yorkshire
hello. around 5 years ago, i bought my house; around 70 years old brick/tile in very exposed position. the roof is chalet style and the stairs to first floor follow the roof line.
couple of years ago, noticed damp on junction of ceiling to stairway and flank wall. about 2 feet across directly underneath single skin chimney carrying gas central heating flue from kitchen. builder worked on chimney - repointing etc. still wet so builder did more work and replaced flashings, checked surrounding tiles etc.
no better and now yellow staining to adjoining bathroom wall. builder investigated further and found inside of chimney stackvery wet (almost mush) and flue liner 'like collander'. He removed chimney stack to just below roof level, relined flue, filed around and added high 'flue pole' on roof with windcatcher flue cap. when relining, builder found flank wall had been lined with plastic at some time in past and plastered over. removed and replastered.
kitchen filled with condensation whenever any wind. ventilation didnt help nor higher flue pole and 'super' cap.. gas guy suggested 'vortex of pressure' and said central heating fumes/gases probably discharging into chimney for years. suggested new system on other wall.
just done this. central heating good. now, no outlet/chimney stack on roof and tiling seems fine. however, wall is getting ever wetter. seems to be two parallel strips of damp approx 2 feet apart running down from ceiling for about three/four feet with one particularly wet spot at bottom. parts showing 'off the scale' on damp meter. can't access from loft ( chimney two feet below loft level) but above that, roof feels dry.
running out of money and patience and fed up with builders shaking their heads. do i need to remove all the old chimney from inside the wall(presumably still contaminated with years of fumes)? can i coat or cover the wall surface with something? how is it getting even wetter when it's now unused?
any assistance SO gratefully received. i think this website might be the answer to my prayers (fingers crossed) Sue
