The master bedroom is the only room in our house left to refurbish. The current L&P ceiling in good condition but it's terribly uneven and massively out of level. Taking it down is not an option due to the mess it will cause.
As the ceiling in the bedroom is high my plan was to lower it by simply creating a timber framework a 10 or so inches below the original ceiling.
Am I correct in thinking the new false ceiling void should be insulated with loft insulation? I always assumed you insulate the part closed to the living space, if I insulate the real ceiling and not the false ceiling, all the warm air would get trapped in the false ceiling void, correct?
I'm also dry lining 2 external walls in this bedroom with timber and insulating with rockwool. Should I use a vapour barrier prior to plaster boarding on both the walls AND ceiling? I'm always a bit wary regarding using polythene in regards to possible condensation issues. The walls are 2 bricks thick and lime plastered. Currently covered in thick wallpaper and paint. Planning to strip the wallpaper only prior to dry lining.
