jungle_jim01
- Loftus, North Yorkshire
Just looking for some reassurance that i'm on the right tracks with this. I've chipped out the cement around a window ready to treat and re-paint. I'm going to use lime mortar to fill the gap around the edge, leaving approx 5mm recess.
Question1 : i've heard it mentioned that i should use well haired mortar...any reason why i can't use plain lime mortar?
Question 2: If i use hair...how much should i add?
I'm then going to fill the recess with burnt sand mastic, overlapping the wood slightly at an angle.
Is this right?
one more question: should i paint the window frames before or after the mastic has been applied?...can i paint the mastic?
Thanks again for everyone's advice...busy multi-tasking with different bits of the house this week!
Is this right?
