Has anyone successfully stripped paint off old beams. Tried wire brush and paint stripper but very hard work. Has anyone tried a peel away paint stripper or sandblasted the beams themselves?
Don't sandblast or you will end up with a crunchie bar effect
A peelaway type stripper is the thing to use. It takes a long time to do and is boring and messy (I am looking at a house full old oak timbers painted black which will need to be stripped one day :roll: ) but you do get up speed as you go ... There are various different products depending on what type of paint you are trying to strip. I will be buying a trial pack
http://www.stripperspaintremovers.com/trial_packs.htm
from my friends at Strippers Paint Removers to do tests to find out which one is right for my paint
I've had success with Peelaway (not on beams but on a bay window), but on oak, make sure the poultice you use is not caustic based or your beams will turn black. Make sure it is just solvent based, so Peelaway 7 is the one to use, not Peelaway 1.
It's very boring and very messy - I've just completed my main room using kling-strip and lots of scrubbing and washing
It did do a great job though at getting the paint off...
I believe others have enjoyed a less painful experience with the jetwash/vac tool that strippers sell but I thought that was potentially too wet for a space were living in at the same time
I was fortunate enough that the beams had originally been lime washed and then glossed in black! so the paint came off quite easily with a paint scraper and again lots of washing and drying.
I used whatever Strippers of Sudbury recommended to get white gloss paint off, I can't remember whether it was Kling-Strip or something else. It was fine, a bit messy but not too bad. You lather it on, cover it with cling-film if I remember correctly, then wash the lot off. Or something like that. Anyway, it has not a scrap of paint remaining, and is undamaged.
I used klingstrip and their vacwash. Not that messy, we weren't really living in the rooms at the time, but one was a kitchen which needed to be used for some things.
I did the kitchen first, then decided it'd be best to do the bedroom before doing anything nice to the kitchen.
Beams now look great.
