"By my understanding lime goes stronger over the period of time by absorbing CO2 which portland cement doesnt." - While this may be true, my understanding and experience is that Lime's final long-term strength will not come close to modern portland. There's a reason they build pillboxes and bunkers with Portland not Lime. In fact, one of Lime's advantages over portland cement is its relative SOFTNESS, as it can break / crumble / deform if the structural masonry (brick or stone) expands and contracts with moisture and temperature fluctuation. This prevents the actual masonry from having to break / crumble / deform (aka spalling) if the surrounding mortar is relatively harder than the masonry, as is the case when cement is used.Dear Aoc
we have a stones at site in abundance so planning to create a framework like gabion walls by welding the wire mesh to the iron angle posts, have stones on both outer and inner sides using lime mortar and soil from the land in between the stones rammed like in the rammed walls (see the sketch), once the desired height is achieved plaster the walls with lime and mud mortar from both inside and outside.
Ohhh I didn't see your location, ok maybe you get away without the insulation. I assumed you were in the UK. I think whether the walls will be fine if / when the gabions rust away is probably dependent on how carefully you build up the masonry within the gabion. When I've built Gabions in the past, I just chucked all kinds of rubble into them and I'm like 90% sure they would have collapsed if the wire was compromised, as I hadn't carefully stacked the pieces in there.i guess the width of the walls are pretty much (21") and even the wire mesh rusts away there should be no problem..
what kind of foundation you think should be good for such thick walls?
the location is near the line of cancer, very very hot region
