GreenKakapol
- London
Hi! We're buying a late-Victorian single-brick house in NE London and it seems like the biggest thing flagged on the survey is rotational movement of the bay window, with the surveyor recommending a Helibar restraint system (see quotes and photos from the surveyor below). To my (very untrained) eye - nothing looks too scary (eg no huge cracks etc) - Would be amazing to get people's thought on:
"Vertical cracking has been observed on both the left and right-hand sides of the bay window, at the junction where the bay meets the front elevation. This is likely the result of rotational movement of the bay, which may be due to either the shallow foundations or possibly the recent window replacements. In my opinion, a restraint scheme should be implemented to prevent further movement of the wall in the future. The recommended solution is the installation of a HeliBar system—a series of stainless steel rods designed to stitch the wall together, providing additional stability. This scheme should be applied at the junction where the bay meets the main walls. I recommend that this work be carried out promptly to ensure the wall is stabilised and to prevent any further movement
Sloping of the floors was observed in some areas at the ground and first-floor level. This was noted on the front elevation of the bay at the ground and first-floor level. The floor in this location was observed to be sloping away from the property. This is likely a result of the rotational movement of the bay. The previously suggested works in relation to the stabilisation of the bay should now be carried out."
- How urgent and serious would you treat this? Something that should be done straight away? If anyone has had similar done - how much it cost, how disruptive it is to interior décor (would paintwork, plaster, laminate flooring etc need to be redone following installation), and was it fully effective?
- What would your next steps be? Talk to a structural surveyor first? Talk to a builder/company who installs such systems?
- How you'd approach in regards to the buying process? Ask the sellers to take the estimate of the work off the value of the house?
