I wonder if anyone can help. I've got a 1750 house that has a newer extension on the back. Typically the Edwardian/late Victorian extension has worse brickwork than the rest of the house. There's a small wall which is 80% window where the ivy had grown through and pushed the plaster off the wall. The previous owners had simply put some wood fibre board over the top with two layers of traditional plaster healing woodchip.
Anyway, I've removed all of the dead lime plaster and gypsum on the other side. The wall has been damp in the past and I'd like this room, just room next door to it lath and plastered.
So today I bought some 25x38 battens and already have plenty of plaster and laths. I then cleared off the existing plaster and spotted a problem.
The issue is that two bricks on the gypsum side stick wildly out by 2cm compared with the rest in the wall. I wonder if the originals were damaged and the previous owners have just put in whatever they could find.
Any suggestions? angle grinder and then SDS chisel a 25mm channel in the brick? Obviously I've not got enough depth in the batten to trim it. Thicker battens would mean that the window would sit at the wrong height in the wall and I'd lose the lovely original trim.
Thanks in advance.
Thanks in advance.
