JoceAndChris
- Lincolnshire
Hi All! Hope all are well and raring to go for the inevitable spring projects!
Our bathroom crawls along at snail's pace, I'm now completely used to not having bathing or showering facilities here. I think it will take a year but will be worth it.
When we disc cut (!!!) out the cast iron bath we found some of the floorboards underneath had rotted out. They're 1920s pine I think. 2.2cm depth and 16.3 cm width. I'm having difficulty sourcing a replacement. Boards now are 2cm depth I've been told by a sawmill. I was thinking a modern redwood would be ok, cut to size, what do you think? it doesn't have to be pretty as it will be covering by a backing board and then slate floor tiles. It does need to take the weight of a bath though ( not a cast iron one this time!) The joists seem good and the rot was in a localised area under the bath seal where the shower water would have dripped down.
Has anyone had floorboards cut to size delivered to them that they've then patched in? Was it ok? Chris wants me to go to the sawmill with the sample and get it matched. It's a long way away though.I haven't found really local places who can do it as the width and depth is problem.
