houblon
- New Jersey
This is just property, neither period nor UK.
My basement walls are concrete blocks, half below ground. Outside is stucco and paint (not great I know), inside is render, most likely lime based.
There is no humidity problem inside. I found a basement window sill rotten below a portion that was covered by a patch of cement:
This cement patch has been added later, since the exposed portion of the bricks was covered with paint. Most of the cement was crumbly and went off easily. The wood behind was wet and rotten. The mortar between the bricks seems to be lime mortar. I removed cement and soft wood, it looks now like this (not as straight alas):
I looked at another basement window that did not have a cement patch, and there seems to be no rot. Am I right assuming that the cement caused this problem? If the humidity comes from the ground, where would it get out (both window sill and walls are painted)?
How can I fix the sill short of tearing it out and replacing it? To splice in a piece of wood I would have to make a straight cut, but I doubt I can get a tool into the tight space.
