Jailhouse John
- 'twixt Dales & Lakes
I alluded on a previous thread to a major problem I am about to face . The lovely house I am about to shell out my hard earned for has the following problem which I am finding impossible to solve.
Consider this:
The house does not have central heating
It does have 3 huge attic rooms under 60 degree (approx) pitched pantile roofs - unfortunately the pantiles are laid over sarking felt.
There is no natural ventilation via the pantiles because of the sarking.
The roof timbers are all original and generally in great condition however rafters and purlins are all rough hewn, of different sizes and arranged in a variety of ways. So cold bridging will be a nightmare.
The attic floors are all Lime-ash, so presumably laid on reed in the part of the world where the house is located. The underside of the ceiling joists is either more reed and plaster or lathe and plaster. So the floor might have a decent u value in itself.
Inconjunction to installing central heating I am looking to insulate the attics using Kingspan - but how? These rooms are each in the region of 30 feet plus x 15 feet so it will be big bucks if it is technically possible to do at all.
So far I have come up with cutting slots in the sarking near the ridge to open up some ventilation to the space that will be created. Build up rafters with more timber so that they are at least level with each other and then fit 1 layer Kingspan inside rafters/built up timbers plus 1 layer over cross laid. Vapour barrier over that and then plasterboard over all of that.
Building Inspectors will have to be involved and there may well be problems with the CO although I am assued that 'they work together'.
Only other alternative I have come up with is to b***** the attics and insulate under the 1st floor ceilings.
Consider this:
