trimattrdg
- HARROGATE
I will be attaching 7’ painted Pine skirting to new lime plaster. Possibly over thinking it but concerned about moisture behind the skirting causing problems . I saw another thread on here suggesting MSP on the rear but have also had limewash on the back suggested which seem very different approaches. The lime plaster goes down to the floor so was planning to fix with screws and plugs into the brickwork . Also. are there any merits to scribing out gaps for ply mounting peices instead of screwing skirting directly to wall?. Previous to this had problems with gypsum plaster board dot and dab even on internal solid walls so keen not to trap any moisture.
