Dampnomore
Hi all,
As the title says really.
I own an ex council semi detached house which was built in 1920, in the 1980s it was modernised internally by the council and since then had work done to it by the previous owner. It seems I have inherited a damp house when purchasing it. I bought during the summer 4 years ago so there were no signs of anything untoward, I didn't really know much about damp back then though to be honest.
The floor is concrete, all the walls throughout the house are brick and is all plastered with gypsum plaster, it is double glazed and has central heating.
Outside, part of the house is rendered with a heavy cast render, I don't know if it is cement or lime based. There are 2 pilasters and a plinth on the front of the house.
The problem I have is that I can't wallpaper anywhere downstairs without the bottom part peeling off. When I originally stripped off the woodchip paper from the whole of downstairs I could see the shape of the brickwork as if the mortar joints were wet, even on the interior walls, some of which had the so called tide lines.
I called a damp surveyor and had a liquid dpc injected through his recommendation which didn't solve the problems, so I called an independent surveyor who said it was just condensation.
I decided to start my own research and try and tackle some work myself which has now opened up a whole new can of worms.
First of all I decided to lower the ground level all the way around the house, then the plinth I mentioned earlier had been rendered over with a cement render and started below the damp proof course up to the top of the plinth, basically bridging the damp proof course. Once I removed this most of the bricks had badly blown and the mortar had turned to dust. The original dpc is made of slate and is now very brittle. One of the pilasters had a loose brick so I took it out and found the cavity to be filled with soil or the dust of the perished mortar, I can't tell which.
I was originally told that the house had no cavity so on 1 of the walls without the pilaster or plinth I took out a brick to check only to find a hell of a lot of expanding foam!
I'm currently confused as to what direction to take now as everything I do to try and find the cause I find more problems.
Any advice would be greatly appreciated.
