Andys
 - At the seaside in Hampshire
It's two years since we had our only surviving corner post repaired, our carpenter popped up for more so we thought we'd better bite the bullet and get the sole plate fixed (also the only remaining section, on the north side away from the effects of the weather)
Here it is as I found it four years ago, hiding behind a cement plinth and looking rather damp and sorry for itself
And here's a section once removed. There's a surprising amount of solid wood left, except at the joints, where it would have been useful
And a few work in progress pics. I have to say it's very exciting having the house held up on acrows and car jacks, including one in the lounge wrapped in an old curtain like a very solid ghost. You can see the insulating blockwork put in by previous owners which might be contributing a bit too.
We were a bit short on stone for the plinth due to the chunks of concrete and stuffed-in bricks which came out, solved by a quick scout round the flower beds (there's a good cartload of it which is lucky in a predominantly clay/shingle part of the country). I wonder if it's been hanging around for 400 years, just in case it comes in useful?
We had two conservation-grade brickies for a week to put it all back together, using a top-up of new Bulmers bricks to augment the many original ones we were able to save. Oh yes, NHL3.5 mortar on the plinth and NHL2 for the infill panels, seeing as you're about to ask...
I think it looks amaaazing and will blend in nicely once it goes off and weathers a bit.
Next job: simply remove the rest of the concrete path and choose a ground level... weed matting and pea shingle for the surface maybe?
Andy
Andy
