Fizzer
- Oxfordshire
We've just take the baffle plate out of our inglenook (to the right of the 1960's 'thing' on the left) - got showered in 47 years worth of soot (as you might expect) but it has given us a good view of the cavernous space within!
The 1960's chimney stops at about the top of the beam then on top of that is what looks like a 8" diameter flue that appears to be made of asbestos
It's only 2 feet tall and vents into the chimney (hence loads of soot on the baffle plate)
We'll get the chimney swept then I'm going to take a look at the flue to see if it's removable in one piece or if its embedded in the stonework.
If so I guess I'll need a specialist asbestos company to get rid of the entire 1960s construction?
Eventually the plan is to install a multifuel stove and I'm hoping that a new flue going all the way up to the top of the chimney will be a relatively cheap option (not having to line the whole thing)
I'm basing this on a lot of assumptions, is anyone can point me in the right direction I'd be grateful!
