robgil said:thanks guys.
so , would it be safe to assume that if a large extension plus a garage had a cement/asbestos corrugated roof then there may be more in the house? perhaps i8n the form of fire bricks or insulation?
and , if you were faced with a 5 meter x 2 meter cement/asbestos roof would you take the chance and remove it your self?
Hatster said:We have an asbestos down-pipe.
robgil said:thank you, so do we.
it will still boil down to a survey although after chasing up the derelict in horningsea and constantly looking below the surface i doubt a survey will shy us away from anything too easily. if i could cope with that old cottage should we have won it this should be a piece of cake by comparison , not that it doesn't come with another long list of jobs to do though , replacing the concrete based render with lime before the wooden frame rots away to dust being one of them , and probably the easiest. :shock:
it will still boil down to a survey although after chasing up the derelict in horningsea and constantly looking below the surface i doubt a survey will shy us away from anything too easily. if i could cope with that old cottage should we have won it this should be a piece of cake by comparison , not that it doesn't come with another long list of jobs to do , replacing the concrete based render with lime before the wooden frame rots away to dust being one of them , and probably the easiest. :shock:
