DevenishEstates
Hi all,
I'm restoring a C16th farmhouse which has a mixture of lime plastered and cement/gypsum plastered walls - fortunately the majority being lime - although in an appalling state.
The floor of the interior of the property (at the rear) is about 1m below the outside ground level (which can't be lowered) and these walls are where the majority of the cement/gypsum has been used - I presume in a forlorn attempt to manage the damp in these walls (wall construction is stone rubble between 600-900mm thick).
I've dug down at the rear of property (outside) to install a dwarf wall (to allow a breathing space between the rear wall and the ground) as well as installing a French drain. Limecrete floors have also been laid throughout.
I propose removing the cement/gypsum to about 1.5m internally and replacing with lime. This will leave me with a lime/gypsum convergence about 1.5m up the wall.
Any ideas how I should approach plastering a finish lime coat to the whole wall - i.e. getting the lime to stick to the gypsum/cement?
I also have a small blockwork wall which I need to lime plaster - will lime readily stick to blockwork - assuming I manage the suction correctly?
In others experience will the planned works (French drain, lime plaster, breathing space, Limecrete floors) successfully allow these walls to dry out?
Any comments/advice gratefully received.
Daron Devenish
(Developer with a conscience and love of old buildings!)
Daron Devenish
