Hi
I'm starting to repoint/render the interior of the house. Now, for certain sections of the walls, I want a particular finish but I don't know how to achieve it. The walls are built of limestone, of varying shapes and sizes. What I want is a render that leaves the shapes of the stones visible beneath the lime. I don't want the actual surfaces of the stones to be visible re. repointing, but I want an undulating finish where you can see see slight bumps and curves where the stones are. Any ideas? Would having quite a wet mixture of lime/sand help? I was thinking of slapping it on by hand and then going over it with a soft nylon brush to get a smooth, but not flat, finish over the stones. I'm planning on using a limewash afterwards.
