Rosemouse
- Tournon Saint Martin
Hello, I am a novice and am learning a lot from this forum. I finally have my own house! It is an old stone house in France that requires quite a lot of work, but it is liveable. I am working on structural and insulation problems first. I had the roof entirely replaced in May with terracotta tiles, and next i need to tackle insulating the attic floor/roof of this two storey house. The quotes I got were to lay two layers of wood batting fibre insulation at right angles to each other across the entire surface. The attic cannot be used as a room - the struts of the roof go right across the width of the attic at a height of about 50cm, so either a false floor would have to be built at that height, leaving not so much space, or the roof trusses would entirely have to be remodelled which would be a ridiculously expensive job - and anyway I don't need the space. So to avoid heating the entire large attic (100m square floorspace) we are going to just insulate the attic floor.
However as I started to learn about thermic bridges and suchlike I realised that I did not know what was underneath the floorboards of the attic. If the space was hollow, as i understand, it would be kind of a bit silly to just dump some insulation on top. Last night, we went up and pulled up some of the floorboards. Underneath we found cavities between the rafters, and those hollow red bricks that were often used here underneath plaster. The cavities were stuffed with newspapers and bits of cardboard (ugh) and dust (ugh ugh) dated to the 50's. The depth from the top of the rafters to the red-brick ceiling is 19cm - the width between the rafters is 43cm. From what I understand, the really best way to do this job properly would be to pull up all the floorboards, which are not in great condition after being underneath a leaking work for several decades, insulate between the rafters first, and then to lie another layer of wood fibre batting at right angles over the top. But should we put a vapour barrier all over and between the rafters first? How do we secure it properly? Does it need to go up the walls around the periphery? And how thick should the second layer of wood batting be?
I am slowly beginning to understand the principles of insulation, I am not very good at physics, but I thought I would pose this question because so many people on here have such great experience and I feel it never hurts to ask. And I don't want a ceiling stuffed with newspaper! Thank you!
