Sue Wilkinson
- Northamptonshire
I posted last week as I started to try to remove cement render from the inside of my rear lobby and loo. It all started out because I needed a sharp corner to practice plastering (as I do soft corners usually) so that I can match up to a sharp corner in a client job I've undertaken.
Well, it went (as usual) from a quick couple of hours to get what I needed, to discovering that the whole lobby and most of the loo were cement rendered. After 3 days of hard work with a lump hammer and chisel it was suggested on this group, that I use an SDS drill with chisel bit. Chris posted many useful links to tool sites etc. It was suggested that a cheap £40 version from B&Q would probably do, but I am wary of cheap tools and certainly couldn't afford the expensive ones Chris was recommending. But I hired one from a local tool hire shop today and its been EXCELLENT! I won't say it was easy, and its been a very dirty job, but I've got all the render off and even better, I've taken up the bitumen floor and revealed the original brick and tile floor!! I'm very excited about that.
My arms are like jelly and my eyes are full of dust still (I got so hot I kept steaming my goggles up so only wore them when actually chiseling) but the nasty stuff has gone into a huge number of rubble sacks and is outside.
The floor is very mucky with the soft bitumen from the bottom of the inch thick layer, but I'm hoping I can find a way of removing that. Any suggestions as to how to clean the bricks and tiles up?
So thanks to everyone for the suggestions and recommendations. You inspired me to do a proper job rather than just doing a practice run. Even better, the client has now started talking about how nice it would be if we got the remaining sharp corner off the doorway and plastered round the shaped stone for a smooth curve! Fingers crossed, she's still thinking about it. The problem of balance with the opposite door jamb is no longer an issue as she is hanging a curtain on that side, so hopefully I'll end up not having to do the sharp edge and I'll get a fully restored lobby into the bargain. The loo is being worked on too, but not as extensively until I can aford major replumbing.
Sue
Sue
