malcolm
& Clementine the cat
- Bedfordshire
I've been nosing around the forum for a while and thought I'd say hi. I'm bound to post here asking for help soon. I bought a disused pub in a Bedfordshire village and it's brilliant! It had been boarded up and open to the elements for a year so we moved straight in to dry the place out. The place is liveable so the project needs to be confined to one room at a time.
The early parts of the building could date from as early as 1650. There isn't much left of the original timber frame structure, maybe a couple of internal walls of timber, wattle and daub. In 1850 or thereabouts the house was extended backwards and the roof was raised. That extension is sinking a bit and isn't tied in to the timber frame. Then in the 1920s they knocked the front off and replaced it with a bay windowed affair with structural mock tudor (which is now rotten), and extended the extension (not bonded in either). The photo attached shows a gable with the outline of the original structure visible.
The place came with planning approval for residential conversion but the plans weren't very sympathetic to the building so we've reapplied with more sympathetic plans. The backup plan is to make the place residential under the existing plans and go from there.
I'm new to building. I'm handy enough but have rented past 40 years old so have absolutely no experience of building. I'm known in automotive restoration. I'm finding very little advice out there which is why I'm saying hi on here. First steps are mostly addressing damp - making exterior ground levels lower than inside, and stripping the oil based exterior paint (over lime) that probably worked a bit before all the holes were drilled through it.
