G_amsonad
- County Antrim
Hi, I am a new member. I have read several threads on this forum already and I’m hoping someone might be able to help me out? I would be very grateful for any input.
I bought my house in June 2023 and one section has problems with damp. It is solid stone wall construction, with concrete render externally and internal gypsum plaster. The house is in Northern Ireland (aka its wet). The finished floor level is only slightly above the external floor level. The worst affected walls face south and west. It’s a very exposed site so they take the brunt of the prevailing southwesterly winds. We have had our builder, architect, surveyor and a PCA damp surveyor look at the property. Consensus is that penetrating damp is occurring via inadequate flashings, a disused chimney breast and through small cracks in external render. Condensation is also an issue, which will address by installing extractor fans in bathrooms. Some have suggested a PIV system to aid ventilation further.
Each person has a different opinion on how to address this problem. The PCA member suggested considering a French drain externally, re plastering internally with lime and ideally also replacing the external render in lime. They also suggested the use of an injectable DPC in a couple of areas which I have to say I don’t really buy into.
Our architect suggests using an insulated stud wall and ventilating the void via the attic. I initially was quite keen on this idea, but the PCA member advised that by making the stone wall colder, interstitial condensation would become worse and there could be a problem of damp in the void, damaging the back of the stud.
The builder suggested a DPM (Newton CDM / Visqueen type system) attached onto the internal surface of the stone wall. Then a metal stud system with foam insulation in the void, but we are not keen on foam insulation and again there is the problem of condensation on the stone wall.
A final suggestion was to dry line the wall, again using a metal stud, but not to use insulation and to ventilate the void into the room itself. The theory being that this would avoid making the stone wall colder and worsening condensation.
Everyone can point out a flaw in each of the other plans. Obviously I know that there is perhaps no ‘right’ or ‘perfect’ answer. The lime solution is rejected by most people we have spoken to, saying its fine in sunny SE England but no here in Ireland. But it must be used successfully in equally wet areas of the UK?
Finally, my wife is concerned about lime houses just being damp e.g. it doesn’t fix the problem but the material can just withstand the dampness better. Is this true or are lime rendered houses dry and comfortable?
Apologies for long post, look forward to any pointers!!
Gregor
Gregor
