I have been trawling through previous 'damp' threads on the forum but wondered if anyone would be so kind as to answer my own specific query.
We are in the process of purchasing an older property. The frontage appears to be victorian but the rear sections are considerably older (I know that is not very specific - 1800ish, we think). We have just had a fully building survey carried out by a surveyor experienced with period property.
The house has solid brick walls (a variety of 9" and 13.5"). The house is an end terrace with a pavement to the front and a tarmac road abutting the end of the property, the road is quite a steep slope, going downhill to the front of the property. The ground level outside is consistently level to or higher than inside. Inside a solid concrete floor has been laid at some point in the not too distant past. It will come as no suprise to you that the exterior walls have been found to contain consistently high moisture levels. The surveyor has recommended stripping the walls back to bare masonry to assess what is going on and allow them to dry out to some extent.
My question is where do we go from there?
I guess ideally we would lower the external ground level and re-plaster with lime internally. It will not be possible to lower external ground level as it is pavement/road. I think it is likely that it will be prohibitively expensive to completely re-plaster in lime (the property is quite large). Any tips on what we can do to make the house as dry as possible whilst being sympathetic to its history? We know there are also some issues with rainwater goods discharging at the base of the walls and these will be sorted as a priority.
Thanks in advance for your advice. I anticipate posting many more questions (hopefully shorter!) and of course pics as soon as the house is officially ours.
