tulipcocoa
Can you help? We have had an architect put together a works specification for the repair and renovation (conservation) of our roof and other roof level and external walls work.
The specification describes each area of work, but not in great detail. So, for example, areas of the back need to be re-rendered and he has asked contracters to quote on a per metre basis. The lead gulleys and flat roofs need to be repaired but he has not indicated exactly where.
In short, there doesn't appear to be enough detail.
The result is that many contractors have said they will only quote on a time and cost basis and others have come up with their own specifications which are similar to but differ from the specification sent out by the architect. None of it fills me with confidence!
I am now considering hiring another surveyor to "fill out the details" in the works spec to try and pin the contractors down a bit more. Do you think this is sensible or am I being too cautious and really I should just go with the flow and work things out along the way?
Does anyone have any experience of this they can share with me?
Many thanks
Many thanks
