We have an Edwardian house that we have been loving restoring with original features throughout. Last year we had a new patio laid and, despite me flagging concerns at the time, there were two points at which the raised patio became almost level with the bottom of the air bricks. I am sure that, in one room, this has now led to a degree of damp through the plaster ( I can't check the other room because the wall is panelled) We have a timber sub floor so I am assuming the bricks are still needed for ventilation - although both rooms are served by additional bricks in the walls that remain a good height from the ground. Should I block up the two air bricks causing concern, leaving the other bricks to ensure adequate ventilation? Or, should I seek some other solution e.g: half concreting the two bricks to increase clearance from ground level while still providing some ventilation, or installing a gully surround to help reduce possible ingress in wet weather?
First hand experiences, ideas or suggestions would be much appreciated. Thanks in anticipation.
