Hi All,
I am pleased to be making my fisrt post in your forum - There seems to be some very good advice being handled here.
Ok, some facts about my property -
Grade II listed Thatch - Timber Frame with brick infill - c.1620
One thatched extension (timber frame on red brick base) c 1920 or earlier (1st extension)
One thatched extension (rendered breeze block to look "real") c 1950/60
The front of the property seems to have had work at some time or another - the front of the bulding (apart from first extension) is set on concrete blocks (so probably done at time of second extension and before the listing.
The rear of the property seems to be just set on rendereded rocks and bricks
My first question -
The first extension is very tired - the render has fallen from the red brick work which supports the frame and the bricks seem more pointed with mud and debris rather than mortar - . I should really have come here firstly, but last weekend I bought some NHL 3.5 lime and some sharp sand. I asked a builder who renovates a lot of farm properties etc what mix to do, and he suggested 5 sand / 1 lime / 1 cement -(lime to help it breath, and cement to help it set) and it should be ok - Now having read more, I am really worried that I have messed this up - Do I need to rip with all off and do it again with Lime / Sharp sand - and should I point first, and then leave for an age to dry before adding a render (either of 5/1/1 (sand/lime/cement) or 2.5/1 (sand/lime) -
I know there is a lot of opinion about this (having read a few posts here) , not least from a conservation point of view, but also from a longevity point of view . Help -
Second question -
The old man we bought the cottage from seemed to do a lot of tinkering with the cottage and seems to have painted the outside beams in a mixture of a weathershielld type black paint and a bituminous paint - (from the cans inherited)
The white parts seem to be a weathershield type paint also (direct onto brick, and also onto "blown" plaster over brick). Where black paint/bituminous paint was added around the base of the house is where most render cover has been eroded / lost.
What is the best course of action here - strip / remove / live with?
Also, what would be the suitable treatment/paint for the black wood, and should it be limewashfor the white panels -
Sorry for the length.
G
My first question -
Second question -
G
