hey all
need some advice on renovating my property. property is:
- red brick with a wooden crook frame
- no foundations brick shell on clay
- three downstairs rooms one is suspended wood floor the other two are solid with a bitumen covering
- walls have been driled and have a chemical damp course
- all walls have normal pink plaster on them
- upstairs floors are lime ash on reeds on top of oak beams
- kitchen is made of brick but is a lean to construction on the back of the house
we have some problems:
- there are some damp patches showing in the plaster mainly in the room with the suspended wood floor and on the interior walls
- the suspended wood floor has rotted and is unusable its like sponge
- bricks in the kitchen are degraded, it is a new addition and looks unsightly
we would like to modernise the property and make it a little more efficient:
- replace the suspended wood floor with a solid floor as we cannot ventilate the floor space
- install exterior wall insulation
- replace single glazed windows with double glazing
- knock down kitchen and replace with an extension which fits the period looks of the house
- install underfloor heating to all rooms
- install loft insulation
my ideas for these changes are as folows:
- pink plaster hacked off to 1m and replaced with lime plaster or renovation plaster (i'm not sure what the difference is here, is the renovation plaster still breathable?)
- exterior walls batonned and cellotex insulation attached then plaster board over the top (i read this can cause interstitial condensation and in the future mould problems is there any way to ventilate this to reduce the likelehood? they currently have no signs of damp even though covered in pink plaster)
- with the undefloor heating make a channel around the edge of the concrete slab about 6 inches wide which would be filled with limecrete to allow the moisture trapped under the floor to evaporate (would this work had seen it done here http://www.mikewye.co.uk/limecrete_Hybrid_Floor.htm)
- install french drains on the exterior walls
- normal fibre insulation in loft but install vents to help the roof breath and when the property is re roofed install a breathable membrane under the slate
any advice on construction methods and materials would be greatly appreciated
richard
richard
